Hatch
I purchased a m-10 to put in my viper. I also have anti-rachet drivers. Will the cross shaft clear the drivers with the m-10 mounting kit? If I were to put it in the stock location in the front holes it will hit, it know that. I dont' have the mounting kit yet so I was just wondering if the kit moves the shaft back alittle? What else could I do? Thanks.
Call Fast, they are great, they will tell ya...as mine sits its close less than 1/2" or a close 1/2" so I would assume you would catch the center part of the drivers!
http://www.totallyamaha.com/ExpertX_M10/M10 Images/PC240010.JPG
pipdviper
mine would've hit because I have the 9 tooth. Did yours hit your proaction? I had to cut mt teeth down on my 9 tooth drives. I couldn't send them back so I just used them! My m-10 shaft seems to be about the same distance from the drivers as the stocker. I'd say go with the 8 tooth if you can. I'm changing mine out when I go to the 136 this year.
Hatch
Yea , I suppose I can call fast and see what they say to do. I am running the 9 tooth anti -rachet drivers, so Im hoping I can just slide the skid back 1" so they clear. When I had my pro-action skid I had the stock drivers so, no it did not hit. Now it is a problem with the anti's. Anyone else have a m-10 with the anti-rachets? How did you mount the m-10?
