none really in the case,pour some over the crank/bearings during assembly
and rotate,and also during assembly of pistons/rings,wipe some around in
the bore also..
I use a syringe to lube the bearings and stuff, then coat the cylinders with oil. Don't forget to have your rings the right way. Also, put some oil in your first tank of gas for the break in.
