Help! Newbie, Does 2002 SRX 700 motor fit into 1998 MSRX?
dtcam
Sask
I could use some help, i have a chance at a 2002 SRX 700 engine. I would like to know if it will fit into my 1998 700 SRX mountain. Is there any mods that i have to do? Help.
Thanks in advance
well, yes it will bolt right in and everything except the ign. system is the same. Your gonna need to do some fabricating on the ignition system, I think you could swap out the stators and then run the newer 02 flywheel on the 98 stator but youll need to grind off the small magnet that tells the 3d ign system when #1 cylinder is up for the firing sequence, its the magnet on the out side of the 02 flywheel thats real small, the other 3 are all long and the same size. it should fire right up after you do this.
So if I use the 98 stator and flywheel everything should hook up and work the same as the original 98 engine?
Is there anything else i need to know before i buy this engine?
He is telling you to grind the smallest magnet on the inside of the magneto so that it is not being read by the pick up coil everytime it makes a revolution.
