Reeds and spacers?
Have you tried doing a search, I can remember reading that someone did a dyno on them, & stated that it made none to little difference in the hp, & that the setup from factory was the best bang for the buck...
mopar1rules said:
run carbon tech carbon fiber reed petals on the stock cast aluminum cages. don't spend the $ on delta's or boyessen rad valves.
What kind of gain can i expect? I was looking into the V-force reeds. Is it worth it?
no, you would be lucky to see a 1hp gain on a dyno. that's whay I said to get the carbontech petals. just get them when the stock ones are worn out.
