Exciter II SX oil injection cable HELP PLS....
fish6107
ontario
i am trying to remove my engine to i can rebuild it.(i have all the parts for the rebuild) I got everthing disconected except i can't figure out where or what end or how to disconect thre cable to the injection pump. Can some some one suggestion anything?? a pic would be nice too if avalible......
Thanks in advance PLS hurry it's getting cold outside... :brr
IN my srx its dead nut=s below the throttle cable on the carb rack. Hit the throttle and listen and look for it moving as you hit the throttle. Once you see it it shouldnt be a problem to dissconnect unless im missing something.
That is not my problem i know exactly where it is i just can't figure how to get the cable out of the oil pump it goes directly into it not to a lever on the outside of it. i am at a loss
I see now. ANy way to remove it from the throttle lever? Just leave as one piece and then remove it as a whole piece, like unbolt it from the case once you remove the whole engine maybe. Im just throwing this out there I had a 540 exciter or was it a 580 im sure someone could tell me when i was 18 but it ran perfect. <luckily, back then I didnt know how to change a tire, lol>
i think there is a little cover on the pump i installed a new pump on my sx 2 years ago but i cant remember for sure but i can look at mine tommorrow and let you know
i just did what you said and everthing is now out THANK GOD! now i can work in a warm basement..... i was hoping not to have to take all the handle bar covers off BUT oh well it done now.... :letitsnow
Handle Bar cover, come on isnt it just a couple of zippers and whammo, there you are> CaNT be that much work lol!
