cannon3731
I have a 2000 sxr. Will a 2001 srx trailing arm work on my sled?
cannon3731
Thanks for the info Yammyyammy said:certainly
jwiedmayer
I believe they are different caster angles. The Sxr long travel does not share the same caster angle as the short travel sleds. With that being said you'll probably never notice.
Will they fit? Yes
Are they the same? No
The caster angle is the difference. The SRX is 2 degrees less then the SX-R
