M-10 Adjustment
nailsandrails
Northern, IL
When setting the FRA Adjuster... If I am setting it at 1....would that be the first tall mark from the rear of the sled?
In that pic it would be three from that angle...use the front of the block & work your way to the front of the skid...or another way of saying it the more up right the sock is, the more fra is...
NOW you got me thinking...I'll tear into my manual tomorrow & post back...
Like I was saying not 100 % sure, I would count the first large line as 1, 1.5, 2 and so on...give me a min...I'll venture out to the shed & get my fast manual...B.R.B...
I was right, the first big line is 1, 1.5, 2, 2.5 & so on...& you read the front of your block in relation to the scale working towards the front of the skid...hope that helps
What are you trying to achieve...what sled is this on...if its a poo, look on the belt guard there should be a set up decal...
It sounds to me from what blues is saying is that 1 is on the right side of the scale ( rear of skid) and 5 is on the left side of the scale ( front side of skid) Correct me if Im wrong?
snowdust said:
Soooooo This picture is correct?????
In this photo, #1 is 2 & #2 is 3...the scale is the same on each side...that photo represents the RIGHT side of the skid the left side of the photo is the rear, right side is the front...cheers
Ok. A new pic. this looks correct to you? This is in my SRX and I am wanting to set it at 1.5.
