ManhattanMike
Is a 2000 SRX 700 Crank any different from the 1998?
edunn69
Yes, they are different.
The 2000 and newer has a different PTO stub end(bearing surface) on the crank as the bearing is 1 wide unit where as the 98-99 uses 2 smaller side by side bearings and has a groove in the middle for the race, also the pindowels are differnt for the case.
Click here for more info
you can use either crank in your cases with the correct pto bearings on it, I have some if you need one, new or used
