Your thots on this setup
stein700sx
Southern Manitoba Canada
02 Viper ER
Stock motor
Stock jettting
stock gearing
Primary grey spring 4000 engagement wot 8400
HC's heel 2.3
mid 3.3
tip 3.3
Secondary stock spring at 80
Helix - Dalton's 48\36
Stock track with 1" Woody's down the middle
6" carbides on stock skies with 1/4" shim
Besides the track is this a good setup for fast trail riding?
I would personally use the red spring in the clutch and run 4.3 in the middle and the tip and see how it pulls rpm.Youll find most of the time you just cant pull the weight with the gray spring. The red spring is 230/360, the gray is 230/330.
Where can I buy a red spring? Purchased this Viper with this setup in it. Have no extrs parts ie: weights, springs and so on.
youll have to see if super torquer has a candaian dealer, or possibly rich motorsports from here can get one and send it up to you.
