max
- May 6, 2003
have anyone tried the 1.1 inch(lug height) on a mountainmax 2001.how much will the top speed increase.do i have to change gearing?clutch?
thanks max
thanks max
I installed the 1.1 on my 01 700 MM. I also ran 9 tooth drivers. My 700 was also Bender piped & trail ported. I could take a 600 ho rev or 600 xc sp on top end...so...I am guessing it would do an honest 100 mph. I could tie my buds f-3 600 96 skidoo on top end...ski tip to ski tip. With 9 tooth drivers the track is really, really tight but will stretch. Stock gearing on a stock sled with 9 tooth drivers at under 2500' altitude should be fine. The 9 tooth drivers will raise your gearing considerably .
