hoffam19 said:Once it's warm, it should actualy run better in colder weather because the colder the weather the leaner it runs, unless of course its running too lean that spells problems, but with normal jetting, you shouldnt have that problem. My sled ran strong last weekend in temps ranging from -5 to 4 above.
stein700sx said:I was taught many many moons ago in automotive school that cold air made more power due to the higher density which meant more air charge in the cylinder making more hosrepower.
Would not a two stroke do the same thing or are they that much different than a four stroke?
My old 68 Chevelle with a built 327 ran alot harder when the temps were 60f and lower.Very crisp throttle response too.
sxr70001 said:Most sleds come from the factory jetted to run at -15, -20 F to protect them from warranty claims. So yes at warmer temps it will be running richer.
