04 viper
captnviper
Lifetime Member
st paul
04 viper setup?
hey this is a great forum, glad i found it!
wish I found it before I started upgrading my sled. Anyway
just wondering if Im heading in the right direction here is what I got so far.
04 viper
carbon viper reeds
reed spacers
k&n filters
slp can
stock jetting pilots out 2 turns(I did make the remote screw adjusters from tech section)
purchased from hauck power sports
primary black spring std weights
secondary green spring set at 6-1 (is this 60*)
cam g
this is what they sent me and it rips out of the corners traction is the only thing slowing down acceleration now. However my buddies 05 f7 seams to have the top speed advantage still. Tach is at 8500 shifted all the way out. :
Welcome aboard Cpt V...what helix you running...clutching guru's are Turk & mrviper700...there are more I'm sure but these two guys have helped me in the past...bang on each time...like you said can't get a better forum to share info & get help...cheers
04 Viper is a great sled. I have two, one stock the other modified.
Lots of tuning help here. Heelclickers and Heavy hitters are a bit more common here, but i'm sure we'll get you going. If your new to clutching it would be a good idea to get Olav Aaens clutch book. It helped me a bunch and others too i'm sure. :wel:
the sleds at a buddies house and its the helix that hauck sent me so ill have to get over there and check it out.
here's my helix # 8bvfa, any simple gains made to the primary (Im on a tight budget) I would like to get heel clickers but not now.
