Bigsur
My brother has a 1999 SRX, Pioneer Clutch Kit, Bender Silencer, and he has trouble with plug fouling. The compression is about 125 straight across, so the compression should not be an issue. Power valves have been cleaned and adjusted, and the carbs have been cleaned with the stock jetting verified. When he talked to the local dealer, they gave him BR8ES plugs, and told him they should help. He rode with them once (~30 miles), and they look good, but I am concerned that they might be too hot for the engine, leading to detonation and possible burn - down. Any thoughts or suggestions would be great.
Have you ran 9's after the carbs cleaned?
Bigsur
yes - we have. It will run well untill the tight trails, then the motor starts to choke. Any other suggestions?
speeking of choke, have you checked it out, plungers returning all the way
/set to spec??
float set to spec/not leaking??
/set to spec??
