Phazer II Secondary Clutch Options
BigMan76
Chicago SW 'Burbs
What newer Yamaha OEM secondary clutches will work in an older Phazer II? For example, can I take a 99 VMax, 02 SRX, etc. and use its secondary in an older Phazer II (a '91)?
Thanks.
The problem is your primary, you could get a secondary off a 95-98 pz 2 or a 95-6 Vmax, those are the later style secondaries, but they are for a 1 3/8' belt, to make it work you would need a later primary
I'm looking for a stock Yamaha clutch setup from a newer sled that can be used for a roller secondary; if the primary needs to be replaced, that's fine too. Looking to do this in the following sleds: Stock '93 Phazer II LE, '91 Phazer II LE, '91 Phazer II LE that has been stretched similar to a stock Mountain (2" paddle track on it).
Any input is welcomed. Thanks.
