SLP triple pipes for 04 Viper MTn
tage81
Sweden
SLP triple pipes install , 04 Viper MTn
Hi guys, im new to posting on this forum, i have been lead here as this seam to be the heart of knowledge for yammy sleds
now the subject.. a friend of mine is thinking of installing a set of SLP triple pipes on his Viper MTn,
it is now all stock, i would apreachiate suggestions for clutching, jetting, and gearing.. the sled is used mostly used around 0-800m above sea level
all help is apreachiated.. sorry if my english is of, im from Sweden so i hope this explains this lol /Andre
Absolutely, I'm running exactly what SLP recommends for clutching and jetting. By comparison to other riding buddies with 800's, I can climb anything their sleds will as long as track lengths don't get over about 153". After that, track on the ground makes too much of a difference.
Check out the thread called "attention, slp cannister, bad rub on motor case" on page two of this forum, that's something he should check before putting the pipes & can on.
I'm running a straight 43 degree. SLP recommends a 43 when riding over 6000', my main riding area is 6100'. I would like to try a multi-angle, like say around a 47-43, just haven't got around to it yet. Hoping to get a better backshift with it.
I ride at 8,500 to 12,000:
Here is what I'm running. I ride at 8,500 to 11,000 with this set up and get about 8-9 MPG. I'm a hair lean at 8,500 and a hair rich at 10,500. Carb heaters off.
PTO 145, CENTER 147.5, MAG 147.5, Pilots 45, Needles 2.0, Air screws 1 7/8.
Torsion spring silver, Torsion cam 43 degrees, 100 degree twist on secondary.
13.3 steel outer rivet, 13.3 Alum inner, 8DN 10 weights, Green-White-Green spring
I engage at 4,050 rpm and max out at 9,100 out of the hole and settles to 9,000
21 x 40 gearing. I forgot to mention I'm jetted for 20 to 0 degrees air temp. If its colder out I my sled runs a little lean, warmer is richer of course.
thanks guys, what do you think about using either heavy hitter weights or some other aftermarket clutch weights in the Viper? (not heelcklickers)
I haven't. I'm running basically what A K Mnt Viper has:
8dn-10's
13.3mm steel rivet base
can't remember what length tip, longest aluminum rivet, it's only like .6 grams
g-w-g stock primary spring
green stock secondary spring at 70 wrap
Yammie 43 degree helix (stock is a 45)
I originally just had the 13.3mm in the base, but after I added the flow-rites I had to add to the tip.
My sled runs with my friends 800 summit, SLP's set up seems to be pretty good. This is more of a deep pow, hill-climbing set up. My cousin has a '98 Mnt. SRX, he's got a 141" track, anti-ratchets, air mod, carbon fiber reeds. He pulls me drag racing by about 2-3 lengths in 500 feet, but no competition hill climbing. He's getting about 35-37 track speed climbing, I'm getting 48-51. The lower gearing on Viper for stock 120hp really works when you throw triples on it. Unless someone else posts with a good set up, I would start with SLP's set up, your friend could then play with it and see if he can improve it.
