Remove handgrips
snowgowa
New Hampshire
I want to remove the heated handgrip on a Phazer and replace the damaged handgrip on my Vmax4. Is there a good way to do this without damaging the handgrip?
Thanks in advance
Depending on the adhesive, you might be able to heat the bars up and hope the adhesive gives before the grips melt....
I have did this once before with success on my 00 SRX, (remove the rivit 1st if yours has one) I used a heat gun and gently kept working back and forth untill it came free. Dont get to crazy twisting it otherwise you may damage the heater elemement inside.
