no fire
tommey66
vermont
I put the 99 phazer back together today. Bored .040 over with new wiseco pistons. Everything went back together good, now when I tried to start it on the 10th pull with me holding open the throttle a crack she fired over. Problem is I am getting no spark unless I hold open the throttle??? What am I over looking? Its a 1999 phazer 500. Also with the over bore will I need to adjust anything?
If you have to move the throttle to get spark, check your TORS to make sure everything is hooked up right.
should the wires running from the carbs be hooked into the two wires coming from the wiring harness? That is how I have it hooked up.
Bypass them. If you have the throttle out of adjustment it might trigger it. Search on it. But I think you just plug the two harness wires together.
