variable resistor ?
Robnoxious
WILDWOOD IL.
anyone know if its safe to jump out the hand &thumb warmer resistors? wouldnt that be the same as putting them on high, letting full power to the grips.
That all depends. I don't know the specs on that circuit.........if the resister was say 0 ohms to some number....for example, let's say 2000 ohms.......then yes. But if the lowest resistance was .......say some certain number well above 0 ohms, then it might need to be in the circuit so the warmers don't burn out.
