gear oil - noob question 95vmax 600
mainah
Maine
noob question here: how do you read the "full" mark on gear oil? Is there a "sight glass" or something to know when to stop adding gear oil? How much should be in there?
Thanks! The bolt in question is on the front of the sled side of the chaincase (bolt head points to the front of the sled)?
Thanks again.
No, It is one the right side under the brake disc, maybe 3" up from the bottom slightly off center towards the front of the case.
Edit: Also I used ATF fluid and noticed a dramatic difference in ease of movement when the sled is cold as it is much thinner in viscosity than gear lube.
