I finally got all the parts in for my Phazer yesterday. I got a PSI pipe, red pink primary spring, power reeds, 1457.5 main jets, and drilled out the primary nozzle. I also got 96 brand new $180 picks (guy sent me the recipet) off of Ebay for $50 shipped.
The sled pulls awesome, there are no bogs or anything. With the new spring it takes off at almost 4000 rpm instead of 3000 like before so I have to get used to that. My yard is big enough to get up to full rpm, (which is somewhere a little over 7000, its hard to tell) but too small to hold it there. But so far everything seems awesome. The track does spin even more now that the engagement is higher, but I bet in packed snow the picks will work pretty good. The only problem is I cant really make sure it is completely tuned until I got up to Maine, so I will just bring all my stuff with me and hope that it is fine like it is.
Its a long way away, but for this summer the plan is widening the front, rx1 skis, vmax shocks, vmax flatsides, and flat black paint.
Nicko
Argentino Loco
Could you tell me what are you running for the secondary and what weights in the primary......Thanks
Nick
Nick
The secondary is exactly the way that I got it (probably stock?). I am running the stock 8VO weights. I am probably going to replace the secondary spring with the same one but brand new sometime, but I have already spent enough on the sled for this winter.
Nicko
Argentino Loco
thanks for sharing that info.....
Nick
Nick
