SED
- Mar 12, 2004
What is the measurement for the lenght when adjusting the Powervalve cables...srx 700....areall the srx's the same length...Thanks
2.5mm if your talking for the housing??
SED
- Mar 12, 2004
let me reword this...how do you adjust the PV cable....I have done Cat valves before..are Yamahas the same way..If so what is the measurement for the cable...measured from the cable housing to the end of the cable when its off of the servo...or are yamahas measured different
SED
- Mar 12, 2004
Sounds easy enough...So i dont have to take the cables off the servo...
no sir..
