Oil Line Question
bluestreak700
michigan
Putting motor back together and I can't remeber which lines go where to/from the oil pump. There is one tha goes along the bottom of the case. The three outlets on the bottom of the pump all go to the fuel pump I'm pretty sure. The one on the very top of the oil pump and the one nipple on the case right next to the oil pump are the two I don't know which hose goes where. There is a line that comes from under the mag side off the case, does this one go on the pump or back into the case? The oil tank line goes into the top of the pump? I know I shoud've paid better attention when I took it off but I'm ready to get the blue streak back out in the snow and I was in a hurry Thanks.
the pump has five nipples on it. three small ones and two larger ones. the large one pointing down is the inlet from oil tank ,the large one pointing to the clutch side is for the bleeder line . the two small ones pointing down go teed together then through a one way check valve to the fuel pump.arrow on check valve towards fuel pump.the small one on top of the oil pump feeds the nipple on the case towards the water pump this also has a check valve.arrow towards case . the nipple on the case behind the oil pump goes conected to the nipple on the pto side of the case.
