chain case lube
blue missile
bucksport maine
i vaguely remember a post about using atf in you're chaincase is this true? if not what is the viscosity of the the proper lube. short of going tp the yammi dealer and buying a little bottle of the stuff.
I have been useing dex 2 atf for years in several sleds with no problems most of them were high milers chains were replaced at 4500 to 5500 miles fliud yearly i mostly run in the far north in -20 to -40 temps.
used the atf had a leak around the drive shaft. glad i did it because it probably was leaking anyway and i could not see it, gotta love the red color.
