04 Viper Oil Pump Adjustment
It is currently at 22.8mm and uses about 1l of oil to 30l of fuel. This is much more than my previous viper (almost double). If I go to 20mm that will make it even richer, correct?
Right,,but spec is 19.5 to 21.5mm, is your oil cable seated ok?,oil pump
arm returning to idle position?
oi pump adjustment
I thought I'd post this to help people know what you're talking about for the measurement. I have oil pump issues as well my 1st 04 viper used about a quart every 200 this on seems to be using quite a bit more than that.
