1997 MM 700 Bogging, Missing, CDI?
xlimited
Houghton, U.P Michigan
Hello I bought this sled last year and since I've owned it I've had problems with it being boggy on me and Fouling plugs and Dropping cylinders. The sled has 7000 miles on it and all cylinders are at 125 PSI.
I Replaced Spark plug caps last season.
I replaced Rollers, and Spring In primary and ramps and spring in secondary a month ago, all stock.
I took carbs out many times there nice and clean and all stock.
I checked for spark with three brand new plugs at the plug and I had nice blue spark.
It will run but its missing and it seems like the cylinder on the clutch side wants to foul quicker but not always, The other night it was the exhaust side that wasn't firing when I checked it smoke came out. It almost seems like the choke is on but all the plungers are closed and It gives me a lot of black smoke.
One thing is when I bought the sled the CDI box was not attached to the side is was just dangling on the jackshaft bouncing around in there. Thank You bobby,
Would a CDI box from another 700 work as long its the same year?
Go in the tech section under sleds. There will be a sub heading called miscellaneous.
Scroll down to Yamaha manuals, click on MM700 and read the oil pump adjustment check pages.
