I only got 79 MPH in 660' with my srx but I still took first. Go figure. I need to figure this thing out. Anyone run a srx with HH have a good setup? From clutches to gearing? Next race is 1000'. HELP!!!!!
![Head Bang :o| :o|](https://totallyamaha.net/images/smilies/banghead.gif)
RmRider01
Pm Pro116 that's my brother he use to have a srx set up for 1000ft speed runs with heavy hitters.
Bakemono
Were you cleaning out the pipes before you ran? If not, a lot of your problem could have been that the pipes were cold.
Before you run, put the back of the sled up on a jackstand and just hold the throttle wide open for half a second. Do that 3 or 4 times before each run and you should be good to go.
If you let a 2-stroke sit and idle for a bit, the pipes will cool off and it will take a little while before the pipes heat up again and it runs right.
Roost 'Er
Maddog what gearing did you end up running?
I ran a 1.90 ratio.
20/38 with a 68 link chain.
What should he see for mph in 1000'?
Yamaha 40th
Maddogs700srx said:I ran a 1.90 ratio.
I think that is a way to tall ratio for 660 you need to pm B-Rad on here we run a little radar run team and have been running in the same ratio issues....BZ
Zachalyse said:What should he see for mph in 1000'?
anywhere form 100 to 113mph in 1000ft depends on how much time and effort you want to put into it.
A bone stock srx with trail studs runs between 91-94mph typically in 1000ft
B Rad
Need another GEAR 33t
Was wondering if anybody has a 33t hyvo for a 01 Srx.
Thanks!!
Thanks!!
was that on Webster Lake this last weekend?
Ya, My sled sucked but still won.....Beats me? The mod 700 class was some weak!
YAMMIEGOD3:16
IN 660 ON ICE I THINK WITH MY 8BU SET-UP WITH MY 2000 SRX I RAN 97 mph. NOT A DIG BUD, SOUNDS LIKE YOU MIGHT HAVE SOME ISSUES GOING ON. 3:16 (yammie tony)
Ya, I just can't figure it out. All I can say is setup. Gearing seems to be an issue. Motor is tight, PV's are perfect, runs real good just won't go. I had hookup issues for the first 200 feet. Then it would pull hard.
me too^^^. ran my xt 700 stock. I got 80 flat, on my fifth run. but don't feel too bad, there was another srx running 74-76Maddogs700srx said:. I had hookup issues for the first 200 feet. Then it would pull hard.
YAMMIEGOD3:16
WELL YA JUST ANSWERED YOUR WHOLE PROBLEM HERE. IN 660 F.T. 200 OF IT YOU HAD HOOK UP ISSUES ? SO YOUR BASISLY SAYING YOU WERE SPINING. WELL THROW THAT OUT THE WINDOW, AND YOU RAN ON A 460 F.T. TRACK !! HOW YA SUPPOSE TO ACCLERATE ON ICE WHEN YOUR NOT GOING ANYWHERE. DUDE, YOU NEED SOME TRACITION PRODUCTS. 3:16 (yammie tony)
