Is it possible to use a 2000 SRX crank and Case with the cylinders, pistons and everything else from a 98 motor to complete the engine.
yes, all the topend will bolt right on. You will see a differance in the ign system, but if its staying in a 2000-02 srx youll be fine, its the 98-99 thats differnt ign/flywheel
Thanks.
