Sxr 700 No Top End
i'm, runnin an 1 1/4 connected cone camoplast with 1.25 megabites. and still have the 9 tooth drivers. Its a good track with a 1 inch paddle all the way across. I just clipped the center nubs off, so the picks could grab, i have no issues. I'm pullin 117 on my speedo, Its good on hard pack and good in soft snow too!
all throttle no bottle said:
So Puting The 9 Tooth Drive In And Cuting The Track Will Not Work Right .
We are trying to tell you that it WILL work. did you change the gearing or did you just throw the drivers in there?
I Put The 24/38 Gears In It To Get It Back To Stock With The 8 Tooth Drivers. Do You See Some Thing Wrong With The Way The Clutch Is Set Up . The H/c Clutch Has Red Spring With 4.8 Heel Shoulder Empty And End Empty . Also Have 15.6 Rollers . Secondary Has Green Spring Set At 60 And Have 45/39 Helix .
lets try to keep this simple.....and inexpensive!! one thing at a time.
put 3 grams in the tip. if you are, as you say , @ 9000 this should bring you down to around 8500. go back out & race your buds & report back what happens. also make sure you are using a 8dn belt & it is adjusted properly. also keep the track snug. don't believe that crap about a loose track being faster - it's not. the minute you sit on the sled the suspension compresses & the track gets looser.
bob
you need more clamp presure on the secondary. turning that 1 1/4 track with heelclickers....try 70 or 80 degrees! I'm bettin your cluthes are a lil hot. also ash can the 15.6 rollers and get 15's in there. you need more wieght force!!
Snow will be here tomorrow!!! The white pine was great last weekend, made it over to Baldwin, up to Boon and back over to Wolf Lake and back to 14 mile last weekend. It was great on Saturday morning but beat by Sunday afternoon.
WELL I THINK I FIXED IT I ADDED 3 GRAMS TO THE WEGHTS AND REPLACED THE BELT ALSO ADJUSTED SECONDARY CLUTCH. I WAS IN CADILAC THIS WEEK END I SEEN 120 ON THE SPEEDO ON THE ROAD AND RACED MY BUDDYS 2003 F-7 ON THE LAKE I GOT THE F-7 BY 3 SLEDS OUT OF THE HOLE AND ABOUT 3 ON THE TOP END . I ALSO RACED MY BUDDYS MXZ WITH A STROKED 670 . I BLOW HIM IN THE WEEDS BAD . SO I THINK ITS RUNNING GREAT . THANKS FOR THE HELP :2strokes:
