torsion spring,phazer to ovation
xcbullet said:
Will the skid springs from a Phazer work on a Ovation ?
I wonder the same thing since the rear suspensions spring is way to soft/weak on my Ovation/CS-340
Someone know if it would fit ?
I believe the 1987-1990 Exciter and Phazer II's used the modified Pro-Link rear suspension in which the springs were interchangeable. Now, the question is did the Ovation use a form of that same suspension ?
The Phazer-I , Phazer-II and Exciter-I used the same type of rear suspension with small differences.
The rear suspension on the Ovation has many similarities with the above rear suspension....
But will the springs from that one fit on the Ovation ???
The Exciter-II used the SRV rear suspension.
HELP !!
all of those sled listed use the old pro action skid even the srv with verry little differences i have a phazer 1 a exciter 2 and a 85 vmax the only difference ive found is the phazer is a shorter skid by 5 inches the springs appear to be identical
eavery420 said:
All of those sled listed use the old pro action skid,
even the SRV with verry little differences.
I have a Phazer-I , Exciter-II and a 85 vmax the only difference ive found is the Phazer is a shorter skid by 5 inches the springs appear to be identical
I do not agree...
* The SRV does not have the same skid as Phazer-I/II and Exciter-I
* The SRV and Exciter-II uses the same skid.
