..SNAKEBIT..
Yama49601
Go to photolava.com you just click browse to find the pics then the drop down box will resize them. You don't need to even create an account on that site, after you click upload you copy the url out of the little box on the next page and paste it into the image box on here. You may already know about the copy and paste part but some people don't know how to do it.
wow the first pic looks spot on!!!, the second maybe just a tad rich but
very close...
check this out, nice little wright up on wash..
http://www.bikemanperformance.com/tech_detail.php?ta=4
very close...
..SNAKEBIT..
Yama49061, did I do that right if so thanks
I can see all them...
damn what happen? looks like det. got ya??
..SNAKEBIT..
I dont know?? ran this set-up for @ 2.5 to 3 years
I found the spark plug cap about a 1/4" off (I tried to put dielectrical grease in the boots to seal them, and I think it slid up) I think that increased the Heat of the spark and took it DOWN???????
Are you sure you didn't get water in that cylinder. Wish I would have not sold my viper head for pennies now. Maxdlx
..SNAKEBIT..
Water from what? the head gasket?
or from the gas?
or from the gas?
Looks like lean jetting/det., did you dig into that carb and have a look??
..SNAKEBIT..
I didnot pull it back apart YET, I guess I was trying to figure out what to do with it.
everything was cleaned and adjusted the fall and was working fine, I EVEN checked piston wash a couple of times with a light when the plugs were out it always looked good, atleast thats what I thought. I have the carb rack setting there still has fuel in them I guess tomorrow I will drain it out then pull down that carb
montynormand
yes, first piston is about right; Second is running richer than #1; and #3 lean melt down!!
