Just like the title says, do viper trailing arms fit on a SX/SXR chassis?
I would like to fit a pair of Viper ski's to my SX but that would drop the front end about a 1/2" so I would like to use the Viper trailing arms and spindles to gain that 1/2" back. Or, is there another way to gain the 1/2" back?
Mills
Mills
MtnMax600
Yes, like you said, as long as you use the arms and the spindles they will fit the SX fine. Not sure if theres any other way to get the height back.
You will also need the steering arms because the spline is different on the Viper spindles
