Heelclicker set up
x2ryder
Moline, Illinois
2002 ported srx. 192 studs. I am running 21/40 gearing for ditch banging. Currently I have the 40-10's, red spring, 5 grams in the heel, middle hole empty and 5 grams in the tip. Anyone have a good corner to corner setup for these weights. Like maybe putting some weight in the middle hole? Also running Bender 48/36 with green secondary spring at 60. Thanks
If your rpm's are where you want it, leave it. I would wrap the secondary at 80 if your just ditch banging and need a good back shift.
