Yamaouch08
Where can I find a replacement neoprene wheel that Maximum performance sold with their marginal wheel kit? I know they are out of business but I have one wheel that has a flat spot and need to find a replacement,I don't really want to buy a whole new kit from another manufactor unless I have to. If any one knows where I can get one or has one let me know,or even have an extra kit laying aroung i would be interested in that to. PM me if you have any info. Thanks
hi performance engineering sells 2 and 3/4 wheels, I don't know if they will work, whats the shaft size. Maxdlx
Yamaouch08
The wheels are 3 and 1/4. they don't list the bearing inside diameter,I measured mine and the are 3/4maxdlx said:hi performance engineering sells 2 and 3/4 wheels, I don't know if they will work, whats the shaft size. Maxdlx
hiperf.com has 3 1/4 too. Maxdlx
Yamaouch08
I called them,but the bearings are the wrong sizemaxdlx said:hiperf.com has 3 1/4 too. Maxdlx
KZOOVIPER
Try this one 8H8-47320-00-00.
This is the same wheel that goes in the top of the rear suspension. Should be the same wheel that comes in the marginal wheel kits.
