tripplec
I had my 97 Venture 600 out first time since I got it last weekend. Finally, got enough snow on some trails. Some gromed and others not but it seems to be hunting (taking little leaps left & right) and I seem to be fighting a bit more than I should. Maybe because of the deep carbides on the stock skis or the play in the front. There is a bit more play (left right on the right ski than left) likely the end joint worn a bit. I don't know if the outer ones are the same as under the hood. I cannot see them or access them for inspection. This is not going to keep me grounded only slow me down. I don't travel that fast on the trails anyway. But the lurching takes away from an enjoyable ride.
Any feedback on the cause.
PS: On the side of the road with little snow (by that the carbides are hitten the gravel or road here and there) were it's not deep or soft it goes normally.
