papacars
got a problem,on my 2ooo mm 700,i put a riser on,had to change brake,throttle and oil pump cables,now i can't get spark to plugs and can't get brakes to pump up,is there a sensor or something else? thanks
M-Max
check your kill switch wires.
When I changed my brake line I had to pump the crap out of it.
Pump it open and closed real fast. After 20 or so pumps to preasure will start to come up. Then you can bleed it as required
When I changed my brake hose I had to pump it with it unhooked/cracked loose at the caliper to get the fluid moving that direction. Once I did this I was able to bleed it as one normally would. I bet between myself and my daughter we pumped the thing 1000 times and it never did pump the fluid until I cracked the fitting loose.
papacars
thanks
