94-96 vmax 600 GYT carb specs for pipes
sxr1000
minot ND
Does anyone remember the updated carb specs for the GYT twin Pipes? I know it was jets and nozzels but i dont remember what they were.
Off the top of my head I know the nozzles are Q-4. I need to look at home for the rest of that info. You should be able to find what you need by doing a search on the board here. I have posted that info before.
This is everything you need to know...
http://www.totallyamaha.net/forums/showthread.php?t=19595
Nozzles will be different for the 94,95's vs the 96's because the 96's came set up differently.
If you have a '94 or '95 you need to use Q8 nozzles, '96s already had them in there. The spec sheets say to use them in only the LH carb, my Yamaha dealer said that there was a later bulletin that called for them in both RH and LH carbs. So, for myself, I put the Q8s in both just to be on the safe side.
