Mathis
the fuel gage and the hand/thumb warmer isnt working longer on my MM700.
The fuel gage now only shows full tank when engine is running. Have checked the fuel leveler that is in the tank, is has the correct ohm (had 5 to 90 ohm) and is not physichally stuck in any position.
Both the leveler and the tachometer only gets 5,8 Volt, suppose it should get 12 Volt. The tachometer is working.
Any thought what can cause this?
voltage regulator
Mathis
where is the voltage regulator placed on the MM?
Mathis
found out where its placed from the online yamaha parts catalogue. have to get it measured today.
Where in norway are you from mathis?
pipdviper
could be a bad ground. Thats what my buddies prob was.
TJ500
what about:
tails lites?
brake lites?
head lites (hi&low)?
tach lite?
Hi beam indicator lite?
speedometer lite?
knowing these might help with diagnosis
tails lites?
brake lites?
tach lite?
speedometer lite?
Mathis
norwegian: i am from Karasjok.
Pipdviper: i tried to measure it with another ground from chassie, was the same low voltage then too.
Tail lights are working, also the brake light is working.
Hi and low head light is working
tach light working
Hi beam indicator also working
speedometer light working
Didnt get to measure anything today, had so much to do today. have to try to do it tomorrow.
tach light working
TJ500
should have read first post more carefully.....(missed the thumb warmer)...
Concur with mrviper700 as regulator is south..
Mathis: I live in Karasjok as well and I also have a MM 01. We should compare our sleds some day. PS. I have the shop manual for that sled.
Mathis
Norw: i see your avatar is from the karasjok river
we should do that some day.
Today i will try to figure out if the voltage regulator is damaged. Would the shop manual have some good info about my electrical problem?
Mathis
seems to be some cable connection problem. Was driving and then the fuel meter
and the warmers suddently started working again... maybe it is the cable that goes under the motor that is damaged...
