vMaxed Out
What do lean and rich plugs look like? I know you want them to be cardboard brown and if they are rich they are dark right? Thanks for the help
rich dark lean clean. Maxdlx
vMaxed Out
thanks. I'm trying to re-install the tempa flow in my sled and have to re-tune it. And I don't have a lot of knowledge about what to look for.
taylzee
I came across this...It might help out...I especially like the avatar at the bottom.
http://www.essexbikers.co.uk/forum/showthread.php?t=137
Go to the Tech section and go to the Engine catagory.Then there is a section that says spark plug information.Everything is explained good on there.Print it out and keep it in your files.
vMaxed Out
thanks for the help. If I run for a mile and stop to check the plugs is that mile to long? I'm afraid of wrecking my motor.
taylzee
1/4 to a 1/2 worked for me.
vMaxed Out
do you mean that 1/4 to 1/2 was enough to tell or was enough to wreck your motor?
1/4 mile is good enough to stop and read plugs..
