I've got a '00 Phazer and would like to install electric start, will I need to source the parts for the '99-'01 only, or will the older Phazers (or any other model for that matter) interchange? Thanks,
Jay
I assume you are talking about finding used parts. I would guess that the starter itself would be the same for all. The flywheel/ring gear I don't know about, there was an ignition system change about 1994. If you have trouble finding the used parts, check with Yamaha and see if there was a kit for it.
