MM clutching?
norwegian
Well-known member
norway
Hi
I have near stock clutching set up from factory on my mm exept that it has the heaviest rivets avaiable. The sled has reed notch mod and hauck headgasket. I also have a hauck green secondary spring wrapped at 80 degrees with the stock helix. My problem is that rpms jump to 9000 when I launch off the hole. What can I do? I have a www spring avaiable and a 50/38 and a 51/43.
Do I need other parts to get the rpms down or what?
Toss in in the 51/43 & it should get rid of the initial overrev.
UPDATE: for my riding a helix with a 51 degree initial angle will make the v-belt very hot.
any one know where I can get a seat to convert mm to a two up , I know there is a kit where can I buy one thanks scott
You can just buy a venture seat from the dealer. Seen those on MM's many times
