butch
what is the stock compresson on a 1975 gpx 433. thankx butch
YAMMIEGOD3:16
GPX WERE PRETTY STOUT. ESPEIALLY WITH THE GYT KIT. COMPRESSION CAN REALLY VARY HERE. 3:16 (yammie tony)
butch
im working on this sled for a freind .it has 150 in each cyl . i am having a problem starting . one time it will start right up the other time it floods ?it does have the power valve carbs on it . i am trying a pair of 38s tomorrow .any thoughts on this problem . thanks BUTCH
YAMMIEGOD3:16
YA YOUR PROBLEM IN THOSE CARBS. 38 ROUND SLIDES SHOULD TAKE CARE OF IT. PROBLEY LEAKING RIGHT THROUGH DIAGRAM ON PUMPS. DRIVE YA NUTS. COMPRESSION IS REAL GOOD THOUGH. 3:16 (yammie tony)
RICKYAMAHA
Hey Yammie tony, what would be the jet setting for the 38 round slides, used without the air box.
YAMMIEGOD3:16
I START ATLEAST WITH A 380 MAINS. 3:16 (yammie tony)
RICKYAMAHA
Then why are they using 260-280 mains on 75 T-jet 440 with 36 round slides
YAMMIEGOD3:16
BIG DEFFERENCE IN SIZE AND FLOW BETWEEN A .36 mm AND A .38 mm. THATS WHY. 3:16 (yammie tony)
thunderjet440
- Oct 30, 2005
Plus a thunderjet has a single pipe.I'm running a 370 main in my gpx,
