Are the hacksaw tracks make alot of noise because of the every third window clipped design? I have always had a howling vibration type problem since I put mine on. Could I get rid of that if I fully clipped it?
ALLSEASONRIDER
Not sure about the Hacksaw, but I believe it is similar to the IceClaw in lug height. Check the clearance at the front cooler. When I installed an IceClaw track on my 01 SXR, it lightly rubbed there causing some noise that went away over time.
I nipped the ends of the track where they rubbed so that shouldn't be the problem.Thanks
Roost 'Er
Nipped ends with lots of studs and no vibs or anything here, i LOVE the track
nailsandrails
Clipped the ends here also. No noise...Excellent track.
JENSEN
any body have a pic of the ends clipped, Im having the same problem...
Roost 'Er
turbor
it only rubs on the heat exchanger protectors, i have some custom ones on mine, the stockers are 1inch thick, mine are 3/4 inch thick and i have 1/4 inch clearance between them and th track. i think they came from royal distributing, but i had to modify them to fit.
