pup55
My son's sled has some USI plastic ski's on it . There is to much weight on the front of the ski's and the carbide is getting worn down. Can you guys give me some info on how to adjust them. I thought I saw somewhere on the site on how to do that.
Follow this link to the Tech pages;
http://www.totallyamaha.com/snowmobiles/aaTECH/Ski_Alignment/Ski_Bumber_Shim.htm This and many other helpful tips are found in the Tech section. If you go to TY Home Page, you'll find it there. This shim mod works great! Have been doing it, at the recommendation of Scott Bergstrom of Bergstrom Skegs, for a long time. Good luck !
Dave
Dave
pup55
Thanks Dave
yup that'll help with darting and front carbide wear...
pup55
I assume this is added to the front of the bumper towards the front of the ski?
No,, to the rear/back of th bumper,look at the pics Dave posted..
pup55
Thanks, I could not tell from the picture.
sure no problem...look at the pic of that bumper,thick side goes to the front
of the ski..
of the ski..
pup55
Thanks again for the help.
No problem...good luck with the issue pup..
how's the carb issue coming along?
pup55
Thanks for asking. I took the tank out and cleaned, also took the fuel pump apart and cleaned and the I did the same thing to the oil tank. I also put in a new fuel filter. I really did not see any reason why my carbs keep clogging. Maybe the fuel filter was starting to come apart from the inside. I have not been able to test do to lack of that white stuff LOL. I hope by cleaning everything that will solve my problem.
Did ya blow all lines out good?
