Alighnment ?
stevoosrx
northern michigan
Ok guys, I flipped my shock brackets and moved from one side to the other. Installed Pioneer shock extensions and am very happy with the heigth of the front now. My question is should I set the camber and toe, the camber looks too negative just by eyeballing it and the toe looks like it is in. Also can any body give me a starting point for the front and rear suspension settings I go about 240 and my back doesn't let me pound around like I used to! any suggestions other than losing about 30 lbs is greatly appreciated
I can't help you with the camber, if it was me I'd talk to Bruce at Pioneer about that to get his insights.As for the toe you definetely want to set that or it won't handle or track right.You want it about 1/4" or so toed out, not in as this won't work good.The front end you'll just have to experiment with the settings,you want a fair amount of ride in and adjust for positive steering and good compliance.As for the rear the full range adjuster is you main adjustment and is checked with your control rod gap with you seated on the sled, you want this gap to be about 50/50 top and bottom.For a clear explanation of these settings maybe go to the technical pages if what I said is'nt clear.An srx is'nt going to be the best ride, but you can optimize what available that for sure.
I live in Grayling, my sister and brother in law live in Onaway.I am very familar with sledding in your area.We came through Cheboygan on Martin Luther King day, the riding was good that day, but it sure was cold that day, maybe zero, brrrr!If theres anything else you need help with just ask and I'm sure somebody can lend a hand, this is a great site!
