hi all i have been reading this board for 2 years, first time posting.
i have an srx 2001 and a fast m10 rear end with the stock track and 192 studs
i was looking to put 20-10 heel clickers in. My question is I don't have to be in the ballpark, but would like to know what would be the best setup, fully dressed 220 pounds. I would like to know how much weight to put in the heel and how much in the tip and also what would be a good multi angle helex to use. My riding style is mostly trail riding 80% lake 20%.
nailsandrails
Welcome to the site!! I'm not the clutching expert on here, but I can tell you about a 52-42 helix with 4-5g heel and 4-5g tip... 70 degree wrap with green spring.. Red clicker spring in primary will work well for you. I assume you meant 40-10 clickers.
Thanks snowdust I have a 50-42 helix 3.8g in the heel 4.5g in tip, a green spring at 60 wrap and a red HC spring. I was checking if I was at the right ball park.
nailsandrails
You sound about right. I had your same set-up just a couple weeks ago before changing suspensions. If you have trouble with traction, you may want to lower your engagement by adding weight to the heel. If it were me I'd wrap @ 70 and add weight to the heel to compensate...assuming your RPM's are where they should be now.
