Bushman
So what you guys think of Camoplast's new Cobra track? Sounds like a good track to run.
http://www.tracksusa.com/cobra.html
journeyman
I want one too. It might be my next track. I saw a couple posts on the 4 stroke side from Apex riders who swapped their Ripsaws out for the Cobra. One guy claimed his Apex hooked better all around on hardpack and loose snow. He also said he gained more acceleration in the midrange and had equal top end as before testing against his buddy. Almost sounds to good to be true.
Bushman
journeyman said:I want one too. It might be my next track. I saw a couple posts on the 4 stroke side from Apex riders who swapped their Ripsaws out for the Cobra. One guy claimed his Apex hooked better all around on hardpack and loose snow. He also said he gained more acceleration in the midrange and had equal top end as before testing against his buddy. Almost sounds to good to be true.
Camo said the Cobra has the same top speed as the Ripsaw but much better pull in loose snow & a little loser in the corners for powersliding. I picked one up the other day & hope to put it in after work tonight. The lugs are very soft though so we will see how it holds up.
Roost 'Er
I almost went with one for the SRX but deemed i wanted lake racing speed to so went with hacksaw looks like GREAT track
I got one on my 08 nytro. Amazing hook up for the softness of the lugs.
Bushman
Cool! Tired of the boys catching me & going by on the bigend, 1.75" lugs really kill topendTurk said:I got one on my 08 nytro. Amazing hook up for the softness of the lugs.
Bushman
Dude that track ROCKS!!!!!! Sure does feel like I have way better hook than with my 1.75" finger. I think I am going to be very happy with the Cobra.
journeyman
Good!! Like to hear that!! My Predator has almost 5000 miles on it. It still is OK, but a few lugs are torn part way down and the cords on the edges are showing. I want to go through the whole sled in the off season. Bearings, true shafts, maybe some Slydog skis and wheels. I may tear it down and re-ring and clean up the ports too. We'll see.
quickone87
i just bought one for my sxr you think ill have clearance problem with studs ????
Yama49601
With a 1 1/4" track 8 tooth drivers should be used if you're gonna run studs. And since these are 1.352"...
quickone87
ok im guna be running 92 redtips 1.52's how hard is it to swap to 8 inch drivers and should i get anti racheting ones to??
