temperature gauge on a viper mtn!hi
Vector88
Labrador, CANADA
hi guys
i got a temperature gauge come today for my 2004 sxviper mtn and i dont know where i can hook the power source for the gauge to. did anyone ever install a temp gauge on there viper before? i need to know where the 2 power source wires goes so the gauge will have power. needs to bea live wire and a ground. please let me know asap!
I was wondering if you could put up some pics of your install when you are done. Thinking of getting one for our vipers.
rx-1mountain said:
hi guys
A clean steady source is the blue wire under the steering pad, I hook all my heated visors this way & ground to one of the four riser bolts...
I ran a long wire down the steering post, under the engine to the pto side & tie wrap to the original harness & back up the hood to the pod/dash on one of my application...
is there a way i can get it to hook up to one of the wires going into the digital speedometer? if not i will do it up to the handlebars but i didnt really want to have a long peice of wire going that far away for a power source!
power
The key is "good steady power". I run a aavenger 3 and have had it hooked up wrong. If your power fluctuates, so does your gauge, ( hand warmers, headlight areas are all a no no. I went to the ignition side after the key. Sleds on gauge works.
