Help guys.... we have a 2000 phazer, started it up toook in the garage, added a 2 inch riser and now it wont idle??? what the heck??? does this sled have tors? it was low on gas, could it be carb problems? if i crack the throttle it will sit there and run fine, but as soon as u let it idle it immediately dies.... HELP the kids are driving me nuts!!!!!!!!
was everything fine before you pulled it in the garage?
tors dosen't effect idle...
yes it was running just fine before..... could it be water in the gas? clogged jets in carb??? kids want to ride..... HELP!!!
pull carbs,clean, is all you can do,may have pulled somthing in....
idle isn;t to low is it???
will it do it after it's been run for a few miles??
taylzee
If you added a riser I'd look into the cables. Some times things get pulled out like the oil cable. Check your cable adjustments.
Yep, it has TORS. You can disconnect and connect the ends together to bypass. Just do this as a test, don't leave it that way of course. Especially with kids riding it.
If it isn't TORS, then . . .
See if it runs with the starter (choke) open halfway. If it does then your pilots are not letting enough fuel through. Either they are clogged or the fuel screws got changed. If it doesn't help it run then you are getting too much fuel. In this case readjust all the cables, which you should do everytime you add a riser anyway.
I just put another one of these back together, they are still quite simple even in 2000.
FIXED!!!! seems the throttle would pull too tight when u moved handlebars to the right... i rerouted the cable a bit and walla gone... running good... will do a little yard test in the AM, but seems fixed.... thanks everyone.
onlyblue said:FIXED!!!! seems the throttle would pull too tight when u moved handlebars to the right... i rerouted the cable a bit and walla gone... running good... will do a little yard test in the AM, but seems fixed.... thanks everyone.
If the throttle was too tight you would think it would idle higher if anything. I have a 1999 phazer that does the same thing. Sometimes it idles fine and sometimes it won't idle at all. If you give it some gas it will stay running and when driving it works great. I have never found the problem myself.
have you tryed adjusting your fuel screw's on top?jaydaniels said:I have a 1999 phazer that does the same thing. Sometimes it idles fine and sometimes it won't idle at all. If you give it some gas it will stay running and when driving it works great. I have never found the problem myself.
daman said:have you tryed adjusting your fuel screw's on top?
No, I'll have to give that a try though. Maybe its a bit rich or something.
My '94 PZ would do that,idle fine at times then not at othere's,PITA,,i leaned up the screw's some and it helped,,idle's great now..jaydaniels said:No, I'll have to give that a try though. Maybe its a bit rich or something.
daman said:My '94 PZ would do that,idle fine at times then not at othere's,PITA,,i leaned up the screw's some and it helped,,idle's great now..
Are the screws the same as an SRX? Turning them out richens the circuit and screwing them in leans it out?
iirc i turned them IN a 1/4 to 1/2(lean).....on these PZ's if your too rich on the idle circuit she won't idle right..
