Primary Clutch lash - is there supposed to be?
Mills
Elk Mound, Wisconsin
I was using my primary clutch ('99 SX 600 triple with stock clutch) to spin the motor over by hand. When I did this I noticed that the movable sheeve would start to rotate a slight bit before the fixed sheeve like there is some "lash" between the two halves of the clutch. Is this a problem or do they do this? I recently had the local yamaha shop take the spider out of the clutch to put new bushings in it and I am wondering if they got everything put back together right.
Mills
There should be very,very little play,,there is a spec for your sled(find it)
and check your's..
sounds like your over tho,usally it's like .03 or .045mm,somthing like that..
