journeyman
Has anyone tried these on a Viper? Just curious.
yammieguy
ttt would you want the 50 or the 60 gram base weight for an srx?? I would think the 50 but looking for feedback
extreman1
- Feb 3, 2004
Just Installed havnt had a chance to run it, trying to get jetting correct.journeyman said:Has anyone tried these on a Viper? Just curious.
I will let u know...
yammieguy
50 gram base extreman1?
mopar1rules
Heelclicker drag n fly weights
WHAT THE HECK ARE THESE? can someone post pics?
extreman1
- Feb 3, 2004
no 60 mine got pipesyammieguy said:50 gram base extreman1?
yammieguy
extreman1 said:no 60 mine got pipes
Even piped I was only thinking you would use 55-58 grams but I have never used heelclickers. Do they generally take more weight than say a factory setup ie: 8bu, 89a, etc.?
extreman1
- Feb 3, 2004
super torquer will set u up with the baesline kit, it is pretty close. I havnt got to do a 1/4 mile run but it does seem to pull hard on a short chop on the throttle.yammieguy said:Even piped I was only thinking you would use 55-58 grams but I have never used heelclickers. Do they generally take more weight than say a factory setup ie: 8bu, 89a, etc.?
extreman1
- Feb 3, 2004
Just ran a apex, about 500 ft maybe more, drag n fly kit set up by super torquer for a piped viper I installed what they sent me. and it run well, under revs about 100-150 rpms so its real close. raced 3 times viper won all.yammieguy said:Even piped I was only thinking you would use 55-58 grams but I have never used heelclickers. Do they generally take more weight than say a factory setup ie: 8bu, 89a, etc.?
